Home > Message Board > Home Audio > Amps > Archive through September 11, 2005 > Best way to wire my amp
Author Thread: Best way to wire my amp
Username: Swede1
Gainesville, Fl
Hi,
I have been installing (trying) a sound system on my boat. I have 4 clarion 100W speakers, a Bazooka 200 W passive woofer, and using a clarion APX480M 4 channel (4X120)amp. Everything has been fine until I decided to get the woofer...I really cannot figure out how to wire it for the best performance....what I did was to wire the 2 left speakers in parallel on one channel and the same for the right....and then hooked the woofer to a single channel (should I bridge it??). I figured that way I could filter the speakers and the subwoofer individually (there are built in high/low pass filters). But a fellow boater just pointed out that wiring the speakers in parallel increases the power output and I could potentially damage the speakers............any suggestions how to do the wiring ????
Home > Message Board > Home Audio > Amps > Archive through September 11, 2005 > Best way to wire my amp [ « Previous ] [ Next » ]
