Home > Message Board > Home Audio > MP3 and Digital Audio Players > Archive through March 21, 2006 > Help with my mini iPod? :-(...
Author Thread: Help with my mini iPod? :-(
Username: Xbabyphathunnyx
Jeeze, no matter how much I try, my iPod and Library won't update =( I have the plugs all the way in, but when I try to connect them, this one window pops up after a few seconds. It says JESSI LOPEZ (E:-) and it has 4 folders. (Calendars, Contacts, iPod_Control, and Notes)... I X out of it and my iPod says Do not disconnect, but itunes isnt updating the new songs! =(
Te smiley is supposed to be : ) with no spaces.
OMG plz help I need my ipod for my party tomorrow! :-(
Username: Project6
Post Number: 3596
First you have to start iTunes...then connect the iPod.
From there you should be able to see your iPod under "Music Store" and "Shopping Cart"
You can start updating from there
Username: Bearycuddly
Sydney
Australia
Hey there,
My problem is with my ipod mini. I've selected manual updating in my preferences and I manually delete songs and playlists from my ipod when it's connected to itunes. After I delete the songs the ipod does not seem to refresh its memory allocation and it's not allowing me to copy new songs on. It's been saying I have 765 songs on it for the last month but I've deleted about 30 tracks??? Any ideas anyone?
hi, ive had my ipod for like a year already but suddenly i could not charge it anymore everytime i attached it to the plug it gave the apple sighn and then it gave this warning smiley and it showed an unhappy smile and then it goes to the charging symbol it wont budge it wont charge something is really rong with my ipod
Brewsyboy
Berny
my ipod wont put new songs on my ipod and it says Do Not Disconnect for hours Plz help
Brewsyboy
Berny
hey berny u can still diconnect it at the bootom of ur screen on the computer there should be a green arrow above a white thing click it with the right part of the mouse and it will say unplug or eject hardware or it will say something else just click it and then u can take it out!!!!
and dont worry about the music when u download it onto ur ipod it will be there dont worry!!!!
Brewsyboy
thanks
can anyone help me with my problem!!!!
Brewsyboy
It just Worked
Brewsyboy
are you using a generic or a real Ipod charger
benpete22
dos any one know how to make your ipod !!NOT!! sync imidiatly when you plug it in to the computer
Home > Message Board > Home Audio > MP3 and Digital Audio Players > Archive through March 21, 2006 > Help with my mini iPod? :-(... [ « Previous ] [ Next » ]
