Home > Message Board > Home Audio > Amps > Archive through September 11, 2005 > Help, for the love of god
Author Thread: Help, for the love of god
ok, before I ask I know it probable has been posted before, but I am very tired of searching and reading.
I have a home theater system, and i would like to improve it by using a "car" sub(audiobahn) but I also need more power(obviously)to make that work.
So i have a boss amp here are the specifications
4 CHANNEL OPERATION
2 OHM STEREO STABLE
LOW AND HIGH LEVEL INPUTS
MOSFET POWER SUPPLY
2000 WATTS (500W x 4)
VARIABLE HIGH AND LOW PASS CROSSOVERS
BRIDGEABLE
NICKEL PLATED RCA INPUTS, LINE OUTS
SIGNAL TO NOISE RATION BETTER THAN 105dB
FREQUENCY RESPONSE 5 Hz - 50 KHz (+/- 3dB)
CHANNEL SEPARATION: BETTER THAN 90 dB
Now all i need to know is home to power it in my house. But also if you can give me a link or product name I should buy.
Thank you
Username: Project6
Post Number: 3490
Look around for computer power supplies, preferably something that will match your vehicle's amperage.
You could also post this in the car audio forum, where you will get a lot more responses.
Why do you think you would get an improvement by using a car sub? Or is this conjecture?
Username: Frostyda9
Calgary, AB
Post Number: 39
A computer power supply isn't going to deliver the current required. You'll need a high power rectifier to do it. Not worth it, IMO.
Username: Jekz409
Post Number: 11
hmmm a boss amp.. 500x4 at 2ohms? idk go to radioshack and ask for a dc-ac (or whatever way it goes ) adapter deal that might work.. take into consideration though that amp isnt putting out anywhere near 500x4 watts
Home > Message Board > Home Audio > Amps > Archive through September 11, 2005 > Help, for the love of god [ « Previous ] [ Next » ]
