Thread: NAD 3200 volume knob and hissing sounds |
New member Username: Sudhir_k
Post Number: 1 Registered: Aug-05
| Posted on Thursday, August 18, 2005 - 12:13 pm: |
I brought a NAD 3200BEE couple of months back..Recently I have started observing a hissing sound (some thing like static on the phone)in the right speaker when I turn the volume knob. Its more prominent when I use the remote..I called up the dealer and he said it needed some cleaning. Any one's got any idea's on this....Except for the hiss the amp sounds great... |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 5136 Registered: May-04
| Posted on Thursday, August 18, 2005 - 01:01 pm: |
"Any one's got any idea's on this" Yes, save your repair tickets for any work done on the amplifier. If the VC shows problems already, it could mean a defective part that will need replacing instead of constant cleaning. Receipts from all service performed will bolster your case if the time comes to insist the issue be resolved to your satisfaction.
Post Number: 2 Registered: Aug-05
| Posted on Friday, August 19, 2005 - 09:40 am: |
Thanks Jan, I was thinking the same... sudhir |
Post Number: 3 Registered: Aug-05
| Posted on Monday, August 29, 2005 - 12:18 pm: |
Dealer replaced the AMP with a new one free of cost...not even shipping... |
Unregistered guest |
| Posted on Sunday, September 11, 2005 - 01:06 am: |
Just a little note, this is usually a result of dust on the contacts, and does need cleaning. Do not open unit to clean yourself as this could void your warranty. www.digitalhsolutions.com |
