Home > Message Board > Home Audio > Amps > Archive through September 11, 2005 > Connecting 3 8-ohm speakers to amp
Author Thread: Connecting 3 8-ohm speakers to amp
I am setting up a football field sound system. We have a QSC 1850 HD amp powering 2 Electrovoice Sx500+ speakers which will be connected in parralel using Neutrik speakon connectors.
The problem is with the 3 smaller EV speakers for the home stands. We will be using 3 Electrovoice Sx80PI speakers rated at 8-ohms (nom). The QSC 850 amp has a rating of 830W at 4 ohms and 600W at 8 ohms. The amp will be running in parralel bridged/mono mode. What way would be the best to connect the 3 smaller speakers to the amp?
Thanks!
Username: Jan_b_vigne
Dallas, TX
Post Number: 5103
If the amp is capable of 25 or 70 volt output, that would be the best choice for a simple hookup.
Would the best way be a combination of Series/Parallel wiring? The QSC specs for the RMX 850 amp are http://www.qscaudio.com. Click on Products, and the RMX series. Any help is appreciated!
Dallas, TX
Post Number: 5117
What?! You didn't think the answer I gave you was helpful? If the amplifier is capable of driving a 25 or 70 volt transformer coupled distribution system, that is your best solution. The amplifier sees a constant load and the power is distributed evenly across all speakers regardless of the actual impedance of the overall load.
If you don't like that answer, I would suggest you find out what the lowest impedance of the speakers falls to and call QSC. I doubt the amplifier will drive all three 8 Ohm speakers in parallel hook up. A series or parallel/series combination is probably the next best solution.
The specs for the amplifier don't mean diddly if you don't know the lowest (and highest) impedance the speaker goes down to.
Home > Message Board > Home Audio > Amps > Archive through September 11, 2005 > Connecting 3 8-ohm speakers to amp [ « Previous ] [ Next » ]
