Thread: How to connect discman to amplifier? |
Prescot Unregistered guest |
| Posted on Monday, March 29, 2004 - 11:06 am: |
Hey there! I recently purchased a TEAC integrated stereo amplifier. I plan to hook it up to my Sony Discman. The question is: should I connect the Discman through it's "line out" or through the "headphone out"? Does it have anything to do with this switch on the amp labelled "Source Direct"? Please help. Muchos Gracias. Prescot
Silver Member Username: Project6
Post Number: 407 Registered: Dec-03
| Posted on Monday, March 29, 2004 - 12:17 pm: |
it is best to use the the "line out". |
Silver Member Username: Gman
Mt. Pleasant,
SC
Post Number: 353 Registered: Dec-03
| Posted on Tuesday, March 30, 2004 - 12:09 am: |
Sony sells for $5.49 on their Sony Style site adapter cables to connect the Discman or Walkman to inputs on the back of your receiver. You can probably get the same adapters from Radio Shack for much less, as normally the Discman has miniplugs that need to be adapted to RCA plugs to input into a receiver. The Discman's line outs can be connected to any open inputs on the back of the receiver, with the exception of phono inputs, which have a different load.
