Thread: Cassette Adaptor Stuck! Please Help |
Unregistered guest |
| Posted on Monday, August 08, 2005 - 04:06 pm: |
I use a cassette adaptor in my car to listen to my MP3 player. Frequently, the cassette adaptor gets stuck and I have to jiggle it around with a key to get it to ejsct, but now, nothing is working. It is stuck in there. Any ideas?
Bronze Member Username: Dvautier
Bellevue,
Wa
Usa
Post Number: 30 Registered: Feb-05
| Posted on Thursday, August 18, 2005 - 04:52 pm: |
that's harsh. kind of like a video cassette. I usually wind up taking them apart. try using a slim jim, or some other long thin metal strip. go underneath and just delicately poke at it. remember the cassette goes in and down on a transport. you have to find out where it is binding. If that doesn't work I can only suggest pulling the unit or praying a lot. |
| Posted on Monday, September 26, 2005 - 09:15 pm: |
yea.. i have that same problem, i even tried pulling on the wire to help it out a little.... but the wire just broke off. i tried prying it out with tweezers. i tried turning the whole thing on & off, i tried pushing a butter knife (gently) underneath. nothing works....  |
Bellevue,
Wa
Usa
Post Number: 35 Registered: Feb-05
| Posted on Wednesday, October 12, 2005 - 09:29 pm: |
You may have to bite the bullet like I did and go with CD. There are few moving parts to a CD player whereas there are legion in a cassette player. Lots of stuff goes wrong. I put all my cassette music on CD. Works so much better. love it. This is not really an answer to your question but just some friendly advice. |
| Posted on Sunday, December 04, 2005 - 02:47 pm: |
I just had a similar problem w/wifes cassette player in a '98 Mazda Protege. The cassette unit made a clicking sound, but the cassette would not eject. The cassette had been stuck for approx. a week before wife mentioned it. I pulled the fuse for the cars audio unit to inspect and the clicking sound stopped. When I reinstalled the fuse, the cassette popped out. I tried the same cassette 2X in & out (both sides of the cassette), and everything appeared to be back to normal. |
