Thread: I think my ears are permanently listening fatigued...? |
abdcaw39 Unregistered guest |
| Posted on Saturday, August 06, 2005 - 11:02 pm: |
What exactly causes listening fatigue? What is it like? I think that my left ear is listening fatigued always. When I listen to a mono source, my left ear always has less treble and clarity than my right. Also when a singer is singing and says something with an s or f sound, it is always louder in my right ear. Is that what listening fatigue is? If so, my ears are permanently fatigued  |
Bronze Member Username: Coiwe
Concepcion,
Bio Bio
Chile
Post Number: 11 Registered: Jul-05
| Posted on Saturday, August 06, 2005 - 11:23 pm: |
Hi abccaw39: I think you should go to see a MD. He can make you some test on a silent chamber and tell you if there is something wrong with your ears. Is better to take care, cause this kind of hearing problems get worst everyday and soemtimes you can't be recover if you don't treat them at the right time. |
| Posted on Saturday, August 06, 2005 - 11:29 pm: |
So then there is something wrong with my ears then, but it can be treated? Thats good that it can be treated I think that it started going like that after I had an ear infection.  |
Silver Member Username: Touche6784
Post Number: 560 Registered: Nov-04
| Posted on Saturday, August 06, 2005 - 11:50 pm: |
i dont think that has to do with listening fatigue. thats more like ear damage. the infection probably did it. i believe listening fatigue is closer to the feeling of literally being fatigued from listening to music with overly emphasised highs. |
| Posted on Saturday, August 06, 2005 - 11:57 pm: |
ear damage? can it be reversed/fixed or evened out between the ears? even if my right ear had a reduction in clarity and matched my left ear, it would be a lot better |
Gold Member Username: Paul_ohstbucks
Post Number: 1874 Registered: Jan-05
| Posted on Sunday, August 07, 2005 - 02:11 am: |
Sounds like you need to take a trip to the eardoctor. Silent chamber??...what's that??? Whenever I've had my hearing checked, I usually wear headphones and listen for a beeping sound. |
Concepcion,
Bio Bio
Chile
Post Number: 12 Registered: Jul-05
| Posted on Monday, August 08, 2005 - 08:59 am: |
Paul: The checking is performed in a place where you can't be disturbed by other sounds. They take you to an special room and THEN, they apply you the headphones as you mention. This is for a very accurate measurements. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 4927 Registered: May-04
| Posted on Monday, August 08, 2005 - 11:26 am: |
Listening fatigue is a problem that occurs while you are "listening" to an audio system. It is typically caused by distortion content - IM distortion is much more disruptive than THD - and goes away after you have turned the system off. It literally translates to, "I'm tired of listening to this crap", though on a far more benign basis. Listening fatigue comes after you've been in front of the system for a period of time and goes away once you turn the system off. Any hearing problems that linger on a constant basis need medical attention. Take my advice, you would not be better off if both ears were having problems. The solution for your problem might be a hearing aid and I have sold many systems to individuals wearing hearing aids who had no problem picking out the piccollos in the recording. Get your problem assessed by a doctor.
