Thread: Connect turntable to pc through mixer? |
New member Username: Carlssounds
Post Number: 1 Registered: Aug-05
| Posted on Friday, August 05, 2005 - 07:24 pm: |
Can I attach a turntable to a mixer then connect the mixer to sound card and get a decent level of sound so I could record vinyls onto cd's? What if i just connect turntable to pc? I read on one of these posts the bush turntable from argos can directly attach to sound card but the signal would be too low. How come? If all you need is preamplifier which the turntable has?! What difference would the mixer make to this rig? I have no phono on my sony av/amp but do have auxilliary on my sharp micro system! Could i connect turntable to micro system? Whats the best solution. P.S the mixer would be second hand but have phono inputs and outputs to pc i presume!
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 4857 Registered: May-04
| Posted on Friday, August 05, 2005 - 07:54 pm: |
Use the table into the mixer into the PC and you will probably get good results. |
Post Number: 3 Registered: Aug-05
| Posted on Friday, August 05, 2005 - 08:11 pm: |
how does the mixer connect to the sound card what leads are required? |
Dallas,
TX
Post Number: 4865 Registered: May-04
| Posted on Friday, August 05, 2005 - 10:15 pm: |
I don't know; that will depend on the sound card. Usually it is a pair of RCA cables. |
Post Number: 5 Registered: Aug-05
| Posted on Sunday, August 07, 2005 - 11:34 am: |
Sound card is bog standard creative soundblaster type. The 'Awe Soundblaster' cards had phono connections I believe, but I suppose mine is a twin rca to mini jack. Thanks anyway. Does anyone know where one could get a cheap terratec phono rig or steinberg clean [not ebay]!PC World [uk] seem to stop selling them [about 60-80 notes]. Anyhow, 1] how would i make sure the signal from the mixer to sound card would not damage soundcard due to the power differences involved? 2]Could I get a lead from the mixer with one end supplying usb the other twin rca[shop said that would be needed to attach mixer to sound card]? 3]Would it be just wiser to buy a top 'Terratec' sound card with preamp built in? any suggestions anyone would be great help..cheers |
Dallas,
TX
Post Number: 4911 Registered: May-04
| Posted on Sunday, August 07, 2005 - 12:26 pm: |
1) Compare output voltage of the mixer to the overload sensitvity of the sound card. 2) Probably not since most mixers don't output a digital signal. 3) Don't know.
Unregistered guest |
| Posted on Friday, August 26, 2005 - 10:26 am: |
i am trying to connect my computer to the radio thru the amplifier using phono cables. Does anyone know if there is a sound card with phono connections. If not how best can i connect the two. |
