Home > Message Board > Home Audio > Amps > Archive through September 11, 2005 > Quick question
Author Thread: Quick question
Username: Music_man
Post Number: 35
Would it be safe to have a 100w 8ohm speaker, on the same channel as a 60w 8ohm speaker?
Thanks in advance!
Username: Touche6784
Post Number: 540
like have them wired in parallel? if that is what you are asking then make sure the reciever/amp can handle 4ohm loads. if thats not it be more specific.
Username: Music_man
Post Number: 36
Thats it my friend! thanks
Username: Artk
Albany, Oregon
Post Number: 1401
Good luck!!!!!!!
Home > Message Board > Home Audio > Amps > Archive through September 11, 2005 > Quick question [ « Previous ] [ Next » ]
