Thread: Speakers for Nad 3020 |
New member Username: Vominhtan74
Can Tho,
Can Tho
Viet Nam
Post Number: 2 Registered: Sep-04
| Posted on Monday, August 01, 2005 - 09:53 am: |
Dear All, I have a Nad 3020 too, please give me to choose a secondhand spearker for it Thanks |
New member Username: Yan
Mojokerto,
Jawa-Timur
Indonesia
Post Number: 2 Registered: Aug-05
| Posted on Wednesday, August 24, 2005 - 12:28 am: |
is it NAD 3020 old amp ? i have NAD 3030, using AR speaker it's not bad. |
Silver Member Username: Joe_c
Atlanta,
GA
Post Number: 999 Registered: Mar-05
| Posted on Wednesday, August 24, 2005 - 12:04 pm: |
What brands do you have available? How much do you want to spend? |
Can Tho,
Can Tho
Viet Nam
Post Number: 4 Registered: Sep-04
| Posted on Wednesday, August 24, 2005 - 08:29 pm: |
Thanks Yan, What model's is? Hi Joseph coulson : I don't have any attention about Brands; i will spend <500$. Now I play it with B&W 204 (secondhand); Thanks
Gold Member Username: Joe_c
Atlanta,
GA
Post Number: 1025 Registered: Mar-05
| Posted on Wednesday, August 24, 2005 - 09:14 pm: |
Are you able to visit a shop and hear some different speakers? |
Mojokerto,
Jawa-Timur
Indonesia
Post Number: 6 Registered: Aug-05
| Posted on Thursday, August 25, 2005 - 09:57 pm: |
i think, with $500 budget, you able to get for new and nowdays speaker type. second hand speaker is ok, but it's depend on how the old pal usage. because i believe the characteristic of internal material will change especially moving parts. |
| Posted on Friday, September 09, 2005 - 08:01 am: |
I have NAD c3020 matched with B&W DM602s3 sounded great Should be try with your 500$ |
Silver Member Username: Danman
QUEBEC
CANADA
Post Number: 500 Registered: Apr-04
| Posted on Friday, September 09, 2005 - 08:58 am: |
B&W, Wharfedale, Epos and PSB come to mind. They like the warm sound of NAD. |
Bronze Member Username: Vm8444
Post Number: 11 Registered: Aug-05
| Posted on Sunday, September 11, 2005 - 05:34 pm: |
you should think greatly of my recomendations because i have owned both.. paradigm,,say studio 20 used ,,around 400 or a little more,ones more detailed and full.. http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1129630923 or one of my favs ,,linn kans less then 400,,offer ,,very fast fun and musically exciting,, http://cls.audiogon.com/cgi-bin/cls.pl?spkrmoni&1131641400 |
Bronze Member Username: Fps_dean
Williamstown,
MA
Post Number: 78 Registered: Oct-05
| Posted on Saturday, November 05, 2005 - 02:34 am: |
Either the Wilson Watt Puppy 7, Infinity Reference Standard Series V (IRS V), or Krell LAT1s or LAT2s will all do just fine  |
