Thread: Speaker wiring? |
| Posted on Wednesday, March 24, 2004 - 02:46 pm: |
i have just bought new qed speaker cable, and after rewiring my speakers i have found that the left speaker is considerably less clear than the right one, and lacks treble. i have rewired a few times. any suggestions ? |
New member Username: Shorty
Sanford,
Florida
US
Post Number: 9 Registered: Mar-04
| Posted on Wednesday, March 24, 2004 - 04:01 pm: |
Make sure that both of the jumpers are still in place between the terminals of the left speaker.
Bronze Member Username: Timn8ter
Seattle,
WA
Post Number: 21 Registered: Dec-03
| Posted on Wednesday, March 24, 2004 - 07:12 pm: |
Have you checked the polarity? Are you using any kind of connectors (banana plugs, spades, etc.)? |
| Posted on Thursday, March 25, 2004 - 11:34 am: |
i have checked the polarity, and i am not using any connectors. the speakers im using are not bi-wirable |
Seattle,
WA
Post Number: 23 Registered: Dec-03
| Posted on Thursday, March 25, 2004 - 11:57 am: |
1. Make sure both cables are the same length. 2. Avoid making a loop with excess cable. 3. Avoid tight bends or crimps that may break the wire strands inside the cable. 4. Make sure the connections at the speaker and the amp are secure. If all these things are ok and you're sure the cable is not damaged then I would begin to look elsewhere for the problem. |
Bronze Member Username: Smitty
Post Number: 25 Registered: Dec-03
| Posted on Thursday, March 25, 2004 - 12:30 pm: |
I would try switching the wires from the l&r speakers to narrow down the problem. |
| Posted on Friday, March 26, 2004 - 10:38 pm: |
Check if the interconnect cables between your CD player and amp are securely plugged. There could be lossened end on the weaker channel. |
| Posted on Saturday, March 27, 2004 - 03:56 pm: |
i have sorted this out, but i still have a slight problem with rattle at low frequencies in one speaker. can anyone help? |
