Home > Message Board > Home Audio > Speakers > Archive through August 09, 2005 > Magnepag MMG good match with Adcom GF...
Author Thread: Magnepag MMG good match with Adcom GFA-545?
Capital
I've been reading a lot about the MMGs and the consensus seems to be they need power. I have a Rotel pre-amp and 2 Adcom GFA-545 amplifiers (hopefully a 3rd soon for center) they're rated 150 wpc at 4 ohms. Will this be enough power to get the most from the Magnepans?
Username: Artk
Albany, Oregon
Post Number: 1369
Perhaps not to get the most from the Maggies, but it should work fine. May be a little bright, you'll have to listen for yourself.
Home > Message Board > Home Audio > Speakers > Archive through August 09, 2005 > Magnepag MMG good match with Adcom GF... [ « Previous ] [ Next » ]
