Thread: Klipsch RF-10 speakers matched w/Carver 900? |
J. Blue Unregistered guest |
| Posted on Thursday, July 28, 2005 - 12:32 pm: |
Greetings, I need a set of budget speakers for my old Carver 900 amp. 100 watts per channel, 8 imped. I can buy a new pair of Klipsch RF-10's for $400. Would that be a good match? I'll have to order the speakers without listening to them. Thanks. |
Silver Member Username: T_bomb25
Dayton,
Ohio
United States
Post Number: 421 Registered: Jun-05
| Posted on Thursday, July 28, 2005 - 12:36 pm: |
So, why are you so set on the Klipsch? |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 4677 Registered: May-04
| Posted on Thursday, July 28, 2005 - 12:56 pm: |
Ordering speakers based on someone else's opinion and without listening to them is a crap shoot. With the number of speakers available, I can only assume there are speakers you could audition before you purchase to make certain they suit your tastes. Why gamble on the Kilpsch if you can't audition them? There is at least a 50% chance you won't like them.
| Posted on Friday, July 29, 2005 - 03:59 pm: |
Tawaun, I'm not set on Klipsch. I'm just in a small town with very little to choose from. |
| Posted on Friday, July 29, 2005 - 04:02 pm: |
Jan, Thanks. I'm sure you're right. |
Gold Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 1039 Registered: Feb-04
| Posted on Friday, July 29, 2005 - 04:11 pm: |
Ordering Klipsch without listenning to them first might not be a good idea. The lower part of the Reference line sounds a bit bright, and you may not like that. I think the higher end Klipsch sound less identifiable as horns and are more neutral, yet very revealing. Try to go listen! (I'm a Klipsch owner and loving them too.) |
