Thread: Subwoofer directly to TV? |
New member Username: Ccs
Post Number: 1 Registered: Mar-04
| Posted on Tuesday, March 23, 2004 - 03:29 pm: |
I bought a Sony KV-32HS510 TV which has RCA Video/Audio output too. Now I see this Velodyne VX-10 10inch Subwoofer offer ($150 instead of $300) which says: "RCA inputs for connection to the subwoofer/LFE output of a receiver or processor and spring-loaded, high-level inputs" Now, my question: can I connect this sub directly to my TV, or I need receiver? Thank you! |
| Posted on Friday, May 28, 2004 - 10:37 pm: |
you should be able to just as long as the are low level outputs out of the tv and low level inputs to the subs |
| Posted on Saturday, May 29, 2004 - 06:16 pm: |
There isn't, Anonymous (no low level outputs). It will not sound right, Csaba. You need to process the signal output from your TV through a receiver that perferbly has pre-out for a subwoofer. |
