Thread: Popping Center Polk CSI-5 |
| Posted on Monday, July 25, 2005 - 09:19 pm: |
I have a Polk CSI-5 that I just got. Every once in a while it will make a popping sound. I notice it most when playing X-BOX, Halo 2. Is the driver bad or am I under powered? |
| Posted on Tuesday, July 26, 2005 - 06:56 pm: |
I have the same issue. I have tried several receivers and still heard it. I don't think it a power issue because I heard it with a 75 watt and a 100 watt receiver. I have someone checking onit with Polk for me. |
Silver Member Username: Kano
Post Number: 551 Registered: Oct-04
| Posted on Tuesday, July 26, 2005 - 07:00 pm: |
Halo 2 pops for everyone, it's not the speaker. IMO the voices don't get fully directed to the headset when playing Live. Are there other instances? |
Gold Member Username: Paul_ohstbucks
Post Number: 1688 Registered: Jan-05
| Posted on Tuesday, July 26, 2005 - 07:47 pm: |
My center channel speaker was popping once, and when I checked my speakerwire, I learned that one of the connections had come loose. Also, make sure your wires arent crossed. |
| Posted on Thursday, July 28, 2005 - 03:52 pm: |
Kano- Thanks for the insight and I do believe you are correct since it doesn't seem to happen any other time except on Halo 2. Paul - That was the first thing that I checked when it started. Thanks |
