Thread: Receiver for Axiom Epic 80 Package |
New member Username: Ht_neophite
Post Number: 1 Registered: Mar-04
| Posted on Saturday, March 20, 2004 - 11:31 am: |
I am currently in the process of upgrading my very tame home theater system (BOSE Accoustimas 15 / Kenwood KR-V6050) to something a bit more robust. I have decided on the Axiom Epic 80 Package(M80ti, QS-8, VP150, and EP 350) though I'm not really sure on the receiver to choose. I am currently considering the H/K AVR 7200 or the Pioneer Elite VSX-55TXi. For my budget, I have basically $1000-$1200 to spend. I was wondering what the best option would be and/or should I be considering any other receivers or seperates? Any and all advice is most welcomed and appreciated. Thanks! |
Bronze Member Username: Gdawg
Post Number: 94 Registered: Dec-03
| Posted on Sunday, March 21, 2004 - 02:55 pm: |
Kevin, You will need a receiver to drive those 4 ohm fronts. The 7200 would be a better option IMO. The P.E wouldnt like the low impedance. Acording to Pioneer, you void your warranty by driving 4 ohm speakers?? G.DawG |
Post Number: 95 Registered: Dec-03
| Posted on Sunday, March 21, 2004 - 02:56 pm: |
My opening sentance doesnt sound too bright:D I meant a good receiver.:-) |
Silver Member Username: Gman
Mt. Pleasant,
SC
Post Number: 315 Registered: Dec-03
| Posted on Monday, March 22, 2004 - 10:47 am: |
Believe it or not I asked Alan Lofft of Axiom about recommending a receiver to drive the Epic 80 package a few months back. While he didn't mention NAD (although I am sure it is excellent for driving this system) he says he drives the system in house all the time with Denon's and HK's with no problem. The following is his response: Hello Greg, The H/K AVR525 will drive the M80tis with ease. In fact, H/K and Denon are the only receiver brands that I recommend for the 4-ohm M80s (other brands either shut down, overheat and shut down, or limit current output severely into 4-0hm loads). I use the H/K AVR525 and it drives my M80s and M22ti's with no problem. Ignore the warning on the back (Use 8-ohm Speakers). The H/K amps are stable and robust into lower impedances. Thanks for your interest in Axiom! Cordially, Alan Lofft Axiom Resident Expert I would certainly recommend (considering what Alan Lofft said), either the new HK AVR 430 or the new AVR 630--whichever fits into your budget. Another good HK receiver is the 7200 which is on closeout at onecall.com I think onecall.com has the AVR630 at $718.50 and the 7200 at under $800. The only change I would make in the speaker system is to switch out the Axiom subwoofer for the HSU VTF-2, which is on sale online a HSU for $449. It is a killer subwoofer at the price and much better than the Axiom subwoofer.
| Posted on Monday, March 22, 2004 - 04:07 pm: |
if you go to the axiom website and read their forum entries you will find that most of the axiom owners are writing about their system with an HK receiver. |
Mt. Pleasant,
SC
Post Number: 320 Registered: Dec-03
| Posted on Monday, March 22, 2004 - 11:27 pm: |
Maybe that is because of Alan Lofft's recommendation. His being "Axiom's resident expert" I am sure his advice carries a lot of weight. |
Silver Member Username: Disco_stan
Minnesota
Post Number: 105 Registered: Dec-03
| Posted on Tuesday, March 23, 2004 - 10:04 am: |
So would you recommend a NAD amplifier powering Axiom's 4 0hm independance? And how would you describe the sound of the Axioms? I trying to find something that will go great with my NAD C270 amp when I get it. |
Minnesota
Post Number: 107 Registered: Dec-03
| Posted on Tuesday, March 23, 2004 - 11:47 pm: |
Hey Greg how long did it take for you to get a reply from Axiom? I emailed them yesturday and haven't got a reply. |
Mt. Pleasant,
SC
Post Number: 326 Registered: Dec-03
| Posted on Wednesday, March 24, 2004 - 12:25 am: |
Usually a day or two for a reply. It depends how busy things are I imagine. I am sure the NAD line is fine for Axiom 4 ohm's or 8 ohms, just as HK's would be fine. Most speaker manufacturers usually dislike recommending receivers. They don't like to make enemies. Often they will say--"Ask the receiver manufacturer if the receiver is 4 ohm capable". Occassionally you get lucky and they will tell you what receivers they like with their speakers. The Axiom's are relatively lively sounding. They aren't laid back in sound, nor are they as "hot" as Klipsch's. But they are more lively than average. Not a veiled or dark sound. They should work well with both HK and NAD. |
Minnesota
Post Number: 108 Registered: Dec-03
| Posted on Wednesday, March 24, 2004 - 09:34 am: |
Great, thank you very much. |
