Home > Message Board > Home Audio > Mini Systems > Archive through July 30, 2005 > HELP NEEDED PLEASE!!!!!!!
Author Thread: HELP NEEDED PLEASE!!!!!!!
Username: Jmc745
I need help with my sony stereo, every time I try to play something, it says EJECT that it makes like a click sound and says stand by.
It always does this, any body know whats up. please help
THANKS
Alfonso Reyes III
YO CHUY, ALL YOU DO IS TAKE AN EIGHT TRACK TAPE AND SHOVE IT INTO YOUR SONY BUT BE SURE TO LUBRICATE IT REAL WELL FIRST THEN PUMP IT IN AND PUMP IT OUT PUMP IT PUMP IT PUMP IT TILL YOU CAN HARDLY STAND OR SHOUT.
CHUCK-CHUCK-CHUCK-A-BOOM CHUCK A BOOM CHUCK A BOOM CHUCK A BOOM, BOOM-BOOM-BOOM-BOOM-BOOM!
Username: Edison
Glendale, CA
US
Post Number: 778
Sorry but sounds like it might be a time for a new one. You can get better sounding one anyway these days for not too much more.
CD mechanism tend to break down after a while - the technology is not settled yet.
If it is Sony es (the upper line), you might want to get it fixed. If not, I will get a new one.
NAD 521 or 542 will sound better.
If you are careful, you might be able to pick one up cheap on ebay - make sure to talk with the seller about it's functionality. Ebay can be risky, but you can get good deals if you are careful.
Home > Message Board > Home Audio > Mini Systems > Archive through July 30, 2005 > HELP NEEDED PLEASE!!!!!!! [ « Previous ] [ Next » ]
