Home > Message Board > Home Audio > CD Players > Archive through October 12, 2005 > Problems with Alpine CDE-9845 + Speak...
Author Thread: Problems with Alpine CDE-9845 + Speakers!!!
I have recently bought a new Alpine CDE-9845 off of Crutchfield. When I installed the new deck into my car, three of the speakers do not work (the 2 door speakers, and the back left 6x9). I have checked to make sure i connected all the correct wirres numberous times, and have looked online for ideas, but havent found anything. I need any suggestions anyone may have, thanks.
Username: Artk
Albany, Oregon
Post Number: 1100
Please go to car audio forum with your question. Thank you.
Username: Kingzofmemphiz
Oklahoma
Hey i also recently bought the same head unit.i didnt know if it was a good buy or not,check out my post under Alpine.Do you think it was worth the money or not?By the way did you install it yourself or did you get it installed?if not, than i suggest you have a car audio technician take a look at it.
Home > Message Board > Home Audio > CD Players > Archive through October 12, 2005 > Problems with Alpine CDE-9845 + Speak... [ « Previous ] [ Next » ]
