Thread: Outlaw 770 + 950 With Bayaudio speakers |
New member Username: Spazzbecker
Post Number: 1 Registered: Mar-04
| Posted on Thursday, March 18, 2004 - 02:17 am: |
Hi Guys and Gals I have a set "x5" of Bayaudio cube speakers See link http://www.bayaudio.com/cube.html also running 2 Sonance 12" subs I'm researching the Outlaw separates, has anybody ran them with the Bayaudio and Sonance subs? I listen to 60/40 Music/movies. Thanks Carl
Silver Member Username: Gman
Mt. Pleasant,
SC
Post Number: 303 Registered: Dec-03
| Posted on Thursday, March 18, 2004 - 10:36 am: |
I doubt you'll find any people on this site with Bay Audio cubes. As long as your Sonance subwoofers are self-powered, getting the Outlaw Audio combination is undoubtedly overkill for the BayAudio cubes. Those 8 ohm speakers are designed to perform well on any mid-price receiver. If the Sonance subwoofers are passive, you might consider getting 2 Outlaw Audio monoblock amps for them and then hooking everything up to a good mid-priced receiver. But if you feel like spending the money on the Outlaw combo it will certainly drive the speakers easily with a lot of power left over. Just be careful not to drive the speakers into heavy distortion, as the 770 has enough power to fry them. |
Post Number: 2 Registered: Mar-04
| Posted on Friday, March 19, 2004 - 01:29 am: |
Hi Gregory Thanks for the reply, do you have any experience with the bayaudio speakers as I have just got these? What mid-price receiver would you recommend for a combination of Music every day and movies at the week end? Thanks for any advice you have Carl |
Mt. Pleasant,
SC
Post Number: 306 Registered: Dec-03
| Posted on Friday, March 19, 2004 - 10:36 am: |
No experience at all. I just read their information, their specs, their power handling ability, etc. Are those Sonance subwoofers self-powered? What size room do you have? Do you already have HDTV and a dvd player? If so, which dvd player? I ask these questions as the hook ups and performance of some dvd players could be better with different receivers. Such as, if you had a Pioneer Elite 47AVi I would recommend a Pioneer 55TXi receiver for your system, to take advantage of the firewire (i-link). You might want to buy one of the NAD models, from the T753, T763, to T773--depending on how much money you want to spend and which features you want. Another good receiver is the Harman Kardon AVR630 that is available at Onecall.com for $718. If you want to diddle around with a lot of different DSP's whilke watching movies you might want a Yamaha 2400. It doesn't have the superior amplifier sections of the NAD's, HK's, or the PE 55TXi's, but it does have an excellent preamp section.
