Home > Message Board > Home Audio > Receivers > Archive through July 12, 2005 > B&K Components AVR 505 II vs Denon 48...
Author Thread: B&K Components AVR 505 II vs Denon 4806
Username: Dixlon
Hi Guys,
I was all set to purchase the B&K Components AVR 505 II then the Denon 4806 came along and I was hoping somebody can tell me which unit has more value for the money.
Thanks
Dixlon
Username: Edison
Glendale, CA
US
Post Number: 740
Have you heard onkyo TX-LR552?
Username: Edison
Glendale, CA
US
Post Number: 741
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10439378&uwb=uwbc10052
Username: Edison
Glendale, CA
US
Post Number: 742
Personally I wouldn't spend a lot of money on surround sound - especially the receiver, if you are interested in good music - they don't do music so well.
I would get a system like this, and get a different 2-channel system if I wanted a music system.
Onkyo Tx-Lr552 ($200 on the web)
http://www.overstock.com/cgi-bin/d2.cgi?page=proframe&prod_id=1457041
If you want to build a dedicated music system, post it, and you will get many helpful hints.
Don't spend that kind of money on surround sound - you will not get much more for your money, and the music will not be that great.
Username: Artk
Albany, Oregon
Post Number: 1097
The B&K is by far better than Denon or Onkyo. They aren't in the same league. If you have a chance to buy a B&K at a reasonable price the by all means jump on it.
Home > Message Board > Home Audio > Receivers > Archive through July 12, 2005 > B&K Components AVR 505 II vs Denon 48... [ « Previous ] [ Next » ]
