Thread: $500 speaker system - recommendations, please! |
speaker system Unregistered guest |
| Posted on Wednesday, July 06, 2005 - 06:29 pm: |
Recommendations please on 5.1 or 7.1 speaker systems in the $500 price range. I am going to build around a $500 range receiver. |
Silver Member Username: Dakulis
Spokane,
Washington
United States
Post Number: 164 Registered: May-05
| Posted on Wednesday, July 06, 2005 - 08:06 pm: |
You could go for Ascend CBM-170s across the front and HTM-200 rears and pick up a HK 235 or a Denon 1905 from some place like this on eBay and you're around your $1000 price point. The system will sound better than any HT in the box. BUT, I'm a fairly newbie myself so listen and learn. (You might see if you can preview the Ascends close to home, also) or anything else recommended by others. Good luck http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39794%26item%3D5786373734 %26 |
| Posted on Wednesday, July 06, 2005 - 08:16 pm: |
www.fluance.com |
Silver Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 911 Registered: Feb-04
| Posted on Wednesday, July 06, 2005 - 08:38 pm: |
Do you already have the receiver? If not, maybe spend less on it and more on speakers? |
Rimouski,
Quebec
Post Number: 912 Registered: Feb-04
| Posted on Wednesday, July 06, 2005 - 08:40 pm: |
Nah... Forget that. Decreasing by $100 might make a big difference on the receiver but not much of a dent towards better speakers. Something to consider anyway... |
