Home > Message Board > Home Audio > Receivers > Archive through July 12, 2005 > Onkyo 501 vs. ??
Author Thread: Onkyo 501 vs. ??
Username: Donaldekelly
Washington, DC
Usa
Post Number: 219
I have an Onkyo 501 6.1 receiver. Real measurements are about 0.06% thd into 4ohms or 8ohms, and about 46 watts per channel.
So, what is to be gained by getting a "better" receiver? For a small room, but with b speakers on often.
Usually I care more about sound quality when playing classical. I like a forward sound but have fairly forward speakers (Axiom M22, Ascend 170).
Home theater is only an after thought for me. 90% for music.
Is this one of them "you gotta go listen for yourself" deals once you get to a certain wattage and certain thd?
I could probably come up with $400 towards a new receiver. Would prefer $300 or less, though.
Thanks
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 1137
I'm afraid a $300-400 AV receiver is probably not going to give you massive improvement, Don. Unless you are willing to go refurb with Harman Audio at eBay (full original HK warranty)...you should be able to land an HK 235 or 335 in that price range.
For 90% music though I'd lean towards integrated 2-channel amps like this:
http://www.hipposaudiovideo.com/nadc320bee.htm
($400 msrp so you can probably haggle down to $300-350)
or even better,
http://www.hipposaudiovideo.com/nadc352.htm
Crystal-clear, rich, full sound that NAD is famous for especially their 2-channel gear.
Posted wattage and THD for most low-end receivers like Onkyo, Sony, Yamaha, etc. is more often than not dubious. Your ears WILL hear the difference between that NAD and the other mass-market receivers in the $500 and under price range.
Zorro
In addition to Edster's suggestion for NAD gear, you should try
http://www.saturdayaudio.com or
http://www.yawaonline.com/miva/merchant.mvc?Screen=CTGY&Store_Code=YO&Category_C ode=NADAMP
Both are very professional and are authorized NAD dealers as well.
Just another option
I also agree with Edster that if music is your priority a HT receiver would not be the way to go.
Washington, DC
Usa
Post Number: 220
The specs on the onkyo are from a review where they tested the receiver. They are far below what Onkyo says in watts but better than onkyos claim for thd, which is probably pointless to rejoice in anyway since I probably can't hear the difference between 0.08 and 0.06% thd.
Yes, I was considering stereo - since it would be better quality for the dollar. Thanks for the suggestions.
Washington, DC
Usa
Post Number: 221
So, a real significant difference in quality? Worth $400 or so dollars?
I think I hear you saying that, just checking.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 1157
Yes, well worth $400 if you are a music lover. And you can offset part of the cost by eBaying the Onkyo receiver...might be able to get up to $100 for it.
THD specs are even more meaningless than inflated RMS specs, Don. The only time you'd ever hear a difference is by comparing receiver A with 25% THD and receiver B with 5% THD let alone .05% THD.
Of course nobody makes a receiver with 25% THD. Fifteen dollar clock radios, maybe! ; )
Home > Message Board > Home Audio > Receivers > Archive through July 12, 2005 > Onkyo 501 vs. ?? [ « Previous ] [ Next » ]
