Thread: 4 Ohm, 6 Ohm, 8 Ohm?? |
John McA Unregistered guest |
| Posted on Tuesday, July 05, 2005 - 01:56 pm: |
This question began in the receiver thread on THX certification and was suggested to be its own thread. Is there any inherent engineering/sound quality benefit to designing a speaker with a given impedence? I just bought an H/K receiver that suggests not to use speakers of more than 8 Ohms. Am I losing anything with respect to sound quality by following H/K's direction? |
Gold Member Username: Paul_ohstbucks
Post Number: 1547 Registered: Jan-05
| Posted on Wednesday, July 06, 2005 - 12:04 am: |
If you connect 4ohm speakers, you might lose sound quality. If you're shopping for new speakers, I'd recommend taking heed to HKs advice, and stick with 8ohm. |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 1151 Registered: Mar-05
| Posted on Wednesday, July 06, 2005 - 12:46 am: |
Generally the lower the impedance of the speakers, the higher current the receiver or amp must be able to put out in order to run those speakers---in other words the bigger and more expensive the receiver/amp required. So unless you are willing to drop some major cash on a higher end receiver/amp (I'd start at $1000 and go up if working down to 4 ohms) then 8 ohms is the safest way to go. |
