Thread: Do terminations really make a difference? |
Bronze Member Username: Shahrukhd
Mumbai,
Maharashtra
India
Post Number: 64 Registered: Nov-04
| Posted on Monday, July 04, 2005 - 05:07 am: |
Ok guys lets not get into another one of those cable wars here but does the quality of banana plugs really make that much of a difference in the sound of speakers? Also, is "commoning" biwire cables to a single termination (banana plug/spade) a good idea? Can I common two runs of cable into any banana plug or do I need to look for something different. I'm using QED Silver Anniversary biwire cables to connect my Wharfedale 8.1s to my Marantz SR4400. |
Die Poopenchuten Unregistered guest |
| Posted on Monday, July 04, 2005 - 01:46 pm: |
The difference among nanners is probably minimal at best. Bare-wire is the best connection for sound quality though. As for commoning, sounds like a waste of a bi-wire cable to me. |
Silver Member Username: Chitown
Post Number: 153 Registered: Apr-05
| Posted on Monday, July 04, 2005 - 02:08 pm: |
I disagree, I dont't know if bare wire vs. banana plugs make any difference in sound quality, because a good connection is still a good connection. What you get with the convinience of the Banana plugs and the ability to keep bare wire out of reach so that they don't cross however makes the banana plugs much better. Have you tried to shove in 14 gauge wires bare wires into the back of most receivers?
| Posted on Monday, July 04, 2005 - 02:44 pm: |
I don't dispute the usefulness of nanners, but if someone is just going to plug them in once and leave them, bare wire is cheaper (sometimes by quite a bit), and still is still the superior connection (whether you can hear it or not). As for crossing the positive and negative wires, do you think Shahrukh is an idiot? In years of using bare wire, and knowing plenty of other people who use bare wire, I have never heard once of someone doing that. As for the receivers ability to receive bare wire, I suppose it depends on the receiver, but I havn't had a problem with that either. |
Silver Member Username: T_bomb25
Dayton,
Ohio
United States
Post Number: 126 Registered: Jun-05
| Posted on Monday, July 04, 2005 - 04:50 pm: |
Yeah you may lose some conveniencewith barwire,but with a quality wire there will be a sound difference,but idea is to get the best connection for sound quality not not asthetics. |
Mumbai,
Maharashtra
India
Post Number: 69 Registered: Nov-04
| Posted on Tuesday, July 05, 2005 - 12:29 am: |
Die, why do you say commoning is a waste? I only wanna use the terminations at the receiver end (it's true, shoving in two wires is a problem). As for the speakers they'll continue to be bare, my only worry being oxidation. I have some cheap nanners at home but the QED guys insist I go in for their special "airlock" plugs. Was a lil confused. |
Silver Member Username: Diablo
Fylde Coast, England
Post Number: 140 Registered: Dec-04
| Posted on Tuesday, July 05, 2005 - 01:04 am: |
QED airlock plugs are generally a good idea - prevents oxidisation. Though if you want to have two cables going into the banana plug then they are going to have a difficult job making the seal airtight. May be better to use the bananas which you have, but leave enough spare cable to allow chopping off the oxidised bit every so often. |
Mumbai,
Maharashtra
India
Post Number: 76 Registered: Nov-04
| Posted on Wednesday, July 06, 2005 - 02:43 am: |
QED airloc plugs are bluddy expensive. Is it really worth spending so much on banana plugs??? |
| Posted on Wednesday, July 06, 2005 - 10:45 am: |
5ijd okdk d;ld |
Silver Member Username: Timn8ter
Seattle,
WA
Post Number: 250 Registered: Dec-03
| Posted on Wednesday, July 06, 2005 - 12:17 pm: |
The only reason I use banana plugs is because I'm constantly swapping speakers. I've noticed after a while they start to loosen up and vibrate. |
