Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through April 08, 2004 > What to look at to replace my Yamaha ...
Author Thread: What to look at to replace my Yamaha RX-V2300
I'm seeking advice. I have a Yamaha RX-V2300, but have had no end of warranty repair problems with Yamaha gear. Maybe I need to look at another brand, which is more reliable. I have a 5.1 HT B&W CM & ASW CDM speaker set up, and use it 50/50 HT and music. What 100+Watt A/V amp's should I look for to get excellent sound quality, reliability and value?
j
I know that you had problems with the yamaha but i have never had any problems with my yamaha. I say try them again. Try the RX-V2400 from yamaha. Also try Marantz SR-6400 and the SR-7400 as well as the NAD T763 or the Pioneer Elite VSX-55TXi. try these brands and any one you get you cant go wrong.
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through April 08, 2004 > What to look at to replace my Yamaha ... [ « Previous ] [ Next » ]
