Thread: Receiver & speaker compatible? |
Susie Q Unregistered guest |
| Posted on Friday, July 01, 2005 - 06:13 am: |
Help. I have a set of 5.1 Pioneer speakers(it was part of htib system)and I'm needing to buy a new receiver. How do I choose a receiver that will work with these speakers? Thanks |
Silver Member Username: Dmwiley
Post Number: 878 Registered: Feb-05
| Posted on Friday, July 01, 2005 - 09:15 am: |
Depends on whether your speakers have a dedicated or proprietary connection scheme. If not, almost any 5.1, 6.1 or 7.1 receiver will do assuming its wattage is consistent with what your speakers can handle. Do a Google search on how to choose a receiver or check a site like CNET.com. |
Silver Member Username: Stu_pitt
NYC,
NY
Pakistan
Post Number: 191 Registered: May-05
| Posted on Friday, July 01, 2005 - 12:41 pm: |
Make sure the impedences match also. They are usually indicated by a number (mainly 8, 6, or 4) followed by the greek symbol/letter for omega - looks like an O with the bottom missing. If the impedences don't match, you could damage the receiver. |
| Posted on Tuesday, July 05, 2005 - 05:52 am: |
Thanks for your input. But how do I know if it's dedicated or proprietary connected? |
Post Number: 881 Registered: Feb-05
| Posted on Tuesday, July 05, 2005 - 07:43 am: |
If each speaker has an unconnected separate positive and negative terminal it is not dedicated. If it has one or two wires that connect all speakers together it is dedicated and requires certain receivers or adapters for connection. |
