Thread: Yamaha Rxv 800 |
New member Username: Bhasker
New Delhi INDIa
Post Number: 1 Registered: Jun-05
| Posted on Thursday, June 30, 2005 - 08:15 pm: |
I am using a yamaha rxv 800 Now whenever I input a digital signal from the DVD into it, the unit goes into standby mode. The same thing happens on changing DSPs. However on inputing analog signal from the tape deck, there is no problem. Can anyone help me on this. Yamaha does not have any official service centre in India, so it is a problem. Thanks |
Silver Member Username: Stu_pitt
NYC,
NY
Pakistan
Post Number: 185 Registered: May-05
| Posted on Thursday, June 30, 2005 - 09:11 pm: |
Paul should be able to help. He is the resident Yamaha and Cerwin Vega expert. |
Gold Member Username: Paul_ohstbucks
Post Number: 1500 Registered: Jan-05
| Posted on Thursday, June 30, 2005 - 10:30 pm: |
I dont know the answer, other than to suggest something is either not connected or your setup menus arent configured properly. Double check your cables, and DVD player setup menu. |
New Delhi INDIa
Post Number: 2 Registered: Jun-05
| Posted on Friday, July 01, 2005 - 12:20 am: |
It was working perfectly earlier. This problem has occured suddenly. I have removed all speaker connections and checked, but the problem is still there....it also occurs when I try to change the DSP Is there any way to do a factory reset....or somewhere to get hold of a service manual I had recently changed the sub-woofer cable as the earlier on had developed faults, but now the problem occurs, even without any speaker connections |
New Delhi INDIa
Post Number: 3 Registered: Jun-05
| Posted on Friday, July 01, 2005 - 12:21 am: |
It was working perfectly earlier. This problem has occured suddenly. I have removed all speaker connections and checked, but the problem is still there....it also occurs when I try to change the DSP Is there any way to do a factory reset....or somewhere to get hold of a service manual I had recently changed the sub-woofer cable as the earlier one had developed faults, but now the problem occurs, even without any speaker connections |
Post Number: 1506 Registered: Jan-05
| Posted on Friday, July 01, 2005 - 01:38 am: |
Maybe your receiver requires servicing. |
New Delhi INDIa
Post Number: 4 Registered: Jun-05
| Posted on Friday, July 01, 2005 - 02:26 am: |
Problem is that there is no official Yamaha service centre in India....so I do not really kmow what to do |
