Thread: Klipsch 5800 |
ga222222 Unregistered guest |
| Posted on Thursday, June 30, 2005 - 03:16 pm: |
I'm mounting some klipsch 5800 in wall speakers in my basement walls. They are framed with 2x4 with a 1inch gap between the back side of the stud and the concrete wall. There is no insulation in any of the walls. Should I seal the gap between the stud and concrete with say, expanding foam to create a single cavity and maybe add some fiberglass insulation below and above the speaker location?Also maybe provide a barrier between the insulation and speaker area with some cardboard? What size box area with-in the cavity should I leave for the speaker? Is ther a calculation? Acoustics? Boominess? or should I do nothing and let the whole wall act as a chamber? Suggestions or experiences please. I have a drop ceiling (8ft)and the room is 20x40 |
Silver Member Username: Edison
Glendale,
CA
US
Post Number: 725 Registered: Dec-03
| Posted on Tuesday, July 05, 2005 - 12:15 pm: |
Might want to post it on www.audioaylum.com on speaker section. If you make a box, they will sound better - and there is a way to calculate the size, but I don't know. Guys in there probably can help you with that. Have you heard Niles audio and MB Quart speakers? I think they sound better my self - since this is a final speaker selection for you, you might want to seek out even better alternatives, before putting in all that work. |
