Thread: How important is speaker sensitivity? |
Bronze Member Username: Twochordcool
Post Number: 11 Registered: Jun-05
| Posted on Wednesday, June 29, 2005 - 01:35 pm: |
There are very highly reviewed speakers that I want to consider but they have a lower sensitivity rating than other speakers that I am considering also. 89 db seems to be average. But is a drop down to 86 db speakers very bad? For example - Now Hear This! SB-2 – 51Hz to 22kHz 86db 150 Watts Now Hear This! SB-3 – 39Hz- 22kHz 175 Watts 86db??? Paradigm Atom – 70Hz to 20Khz 86 db 80 Watts Paradigm Titan – 60Hz to 20kHz 86 db 100 Watts Epos ELS-3 - 65Hz-20KHz 87db 100 Watts 4 ohms nominal Ascend Acoustics CBM-170 - 69Hz to 20kHz 89db 200 Watts Axiom M3ti – 60 to 22kHz 88 db 175 Watts Axiom M22ti – 60Hz to 22kHz 89db 200 Watts Energy C-3 – 46Hz to 23kHz 89db 125 Watts Monitor Audio Bronze B2 – 42Hz to 22kHz 90db 100 Watts 6 Ohms Unfortunately also, some of the speakers with the higher sensitivity don't seem to have as broad of a frequency response (Ascend CBM-170) Please discuss!
Silver Member Username: Thx_3417
Bournemouth,
Dorset
United Kingdom
Post Number: 477 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 01:58 pm: |
Hallo there Tim. Can I call you Tim , for short that's one long name. Any why the sensitivity based one the 1watt @1meter for loudspeaker loudness with pink noise testing determining the robustness of it, something like that, why Jan can fill a not more of the blacks in hear. As for the front loudspeakers in any professional cinema they must be the same and the same applies to the home cinema as well. Cutting corners will result in poor edge performance with dynamics from the softest voice sound to the loudest yelling screaming sound to the artificial fabrication of explosions. The higher the sensitivity the better, if I had the money I’ll have some high performance JBL cinema loudspeakers for the fronts and they some in all shapes and sizes from single 15in cab with Horn compression two dual 15in cab sizes with huge 3 foot square Horns like the JBL 2360-A which as a sensitivity of around 130db wow no problems there with that little girl from “Aliens” newt screaming to the top of her lungs.
Silver Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 882 Registered: Feb-04
| Posted on Wednesday, June 29, 2005 - 02:05 pm: |
The difference between 86 and 89 is 3 dB, or a doubling of power. It's not so much that I'd worry about it unless you will be using these in a large room. An efficiency of 89 dB is decent but close to average. You won't see a lot more unless you go to horn-loaded speakers, which don't all sound very good until you spend a little more. Add some Klipsch to the lineup above and you'll see some bigger efficiency numbers (or JBL or Cervin Vega). For example: Klipsch B-3 (bookshelf) 55Hz - 23kHz +/-3dB 93.5 dB 85 w (340 w peak) 8 ohms Klipsch RF-25 (floorstanding) 45Hz-20kHz ±3dB 97dB 125 w max continuous (500 w peak) 8 ohms If I were not wanting to spend too much overall, I'd stay away from 4 and 6 ohms speakers and stick with 8 ohms. Your unexpensive receiver will be happier driving them and will sound better. |
Silver Member Username: Stealth_c
Dublin,
CA
Post Number: 249 Registered: Jan-05
| Posted on Wednesday, June 29, 2005 - 02:10 pm: |
Without going too in depth, every 3dB drop in sensitivity requires double the power to drive the speaker to the same volume, all other things being equal. As a result, it is generally beneficial to have a speaker with high sensitivity. "Unfortunately also, some of the speakers with the higher sensitivity don't seem to have as broad of a frequency response (Ascend CBM-170) " Not really. The Klipschorn is plenty sensitive and has a fine frequency range. |
Rimouski,
Quebec
Post Number: 883 Registered: Feb-04
Andy, Why are you assuming that this is for HT? |
Dublin,
CA
Post Number: 250 Registered: Jan-05
| Posted on Wednesday, June 29, 2005 - 02:14 pm: |
Ohh and Andy, it is for a 2.83 volt input, which translates to 2 watts at 4 ohms, and 1 watt at 8 ohms. |
Rimouski,
Quebec
Post Number: 884 Registered: Feb-04
| Posted on Wednesday, June 29, 2005 - 02:15 pm: |
Since Stephen brought 'em up: Klipsch Klipschorn 33Hz-17kHz± 3dB 104dB @ 1watt/1meter 100 w max continuous (400 w peak) 8 ohms |
Silver Member Username: Stu_pitt
NYC,
NY
Pakistan
Post Number: 137 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 02:17 pm: |
I honestly think that Andy is "special." Who's with me? He does make me laugh every time he posts though. Since I bartended at a brew pub in college, I'm going to a beer brewing message board and start calling myself an expert over there. |
Bournemouth,
Dorset
United Kingdom
Post Number: 478 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 02:23 pm: |
Headroom that’s the word I was looking for setting for the max peak 85dbA weighting which will exceed this level, by a few db for argument sakes there will be plenty of headroom with lower distortion values within audio tolerances, so if you like to experiment in this, there is harm doing so. And B-chaining the sound system over what you are using at present boy the differences will be huge active X-over units is the way with low going to the LF range of the bass spectrum from 20Hz to 500Hz and from 500Hz to 20Khz for the high frequency HF range with higher highs, to say that there will be less distortion. If by any chance your loudspeakers have Bi-wireable go and buy an “Active” X-over units at least 3x for the fronts with adjustable frequency range settings as some come pre-fixed at 20Hz to 500Hz to 20KHz with 18db octave down slops, and sending 500Hz to 20Hz into your small HF tweeter will create distortion due to the low sensitivity and it’s frequency range and will later burn the voice coil out. So finding a “Active” X-over with adjustable frequencies, so that you can address the correct frequency to each driver element.
NYC,
NY
Pakistan
Post Number: 139 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 02:29 pm: |
Andy- Hallo there!!! Who asked about any of this? Here you go again. Do we need more proof of him being 'special?' 478 posts of it and counting. |
Bournemouth,
Dorset
United Kingdom
Post Number: 480 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 02:32 pm: |
That’s right Stu, I’m someone special, in fact we all are we all know what we know! To some degree we learn everyday that’s what makes us human, life is trial & error. So Stu, it’s what we do that can help the other out with as many possible options that counts.
NYC,
NY
Pakistan
Post Number: 140 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 02:39 pm: |
Timothy - In my opinion highly efficient speakers aren't as accurate as lower efficiency ones for the most part. The highly efficient speakers that are very accurate tend to cost multiples of the speakers that you mentioned. There are a few exceptions - Klipsch always comest to mind. This is my opinion based on my experience. But I have heard many others say the same thing. |
NYC,
NY
Pakistan
Post Number: 141 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 02:41 pm: |
Andy - Hallo There!!! Great pic!!! You really made my day!!! No more Hallo There!!!? |
Bournemouth,
Dorset
United Kingdom
Post Number: 482 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 02:57 pm: |
HALLO THERE Stu, is that better, need I say it twice, I’m only being polite.
NYC,
NY
Pakistan
Post Number: 144 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 03:06 pm: |
I thought you said it every time and weren't saying it to me any more. My fault. |
Bournemouth,
Dorset
United Kingdom
Post Number: 484 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 03:12 pm: |
HALLO THERE STU, My hero  |
NYC,
NY
Pakistan
Post Number: 147 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 03:17 pm: |
Does that mean you're my b i t c h?
Bournemouth,
Dorset
United Kingdom
Post Number: 485 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 03:22 pm: |
Not at all, any way lets go back to are world of professional cinema Hi-Fi and home cinema. Shall we dance?
NYC,
NY
Pakistan
Post Number: 149 Registered: May-05
| Posted on Wednesday, June 29, 2005 - 03:37 pm: |
You're a good guy Andy, I like you... Not like that though. |
Gold Member Username: Paul_ohstbucks
Post Number: 1478 Registered: Jan-05
| Posted on Wednesday, June 29, 2005 - 08:53 pm: |
Andy, Lay off the pics man...geeez. Tim, As far as sensitivity goes, it depends on what type of listening you do. for some, a high level of sensitivity is important. For example, if you like to blast your movies/music on occasion, having a high sensitivity will make an obvious difference. If not, then it wont matter. |
Bronze Member Username: Audioholic
Post Number: 74 Registered: Apr-05
| Posted on Saturday, July 02, 2005 - 07:00 am: |
"For example, if you like to blast your movies/music on occasion, having a high sensitivity will make an obvious difference. If not, then it wont matter" Won't matter of course unless you have a low powered amplifier.....then it will matter....and matter plenty too. |
Post Number: 23 Registered: Jun-05
| Posted on Saturday, July 02, 2005 - 02:44 pm: |
"Won't matter of course unless you have a low powered amplifier.....then it will matter....and matter plenty too" and what would you consider a low powered amplifier? |
