Home > Message Board > Home Audio > Speakers > Archive through July 07, 2005 > Speakers for musical fidelity 3.2 int...
Author Thread: Speakers for musical fidelity 3.2 integrated
Username: Fudge
Glastonbury, Somerset
United Kingdom
hi,has anyone used Castle speakers with MF? ,at the moment use Mission 782s ...have a high ceiling and also want to listen at low levels,
any suggestion welcome...use Exposure 2010s cd player at front.
Thanks
Username: Edison
Glendale, CA
US
Post Number: 717
Epos 12.
Your present systems should sound ok.
What are you not happy with your present setup?
Perhaps you can get improve by tweaking other things - like getting a power conditioner on ebay - oneac or powervar.
Also if you really want good sounds, you will be rewarded to improve the room acoustics with treatments.
Since you already have pretty good components, I would suggest treating the power, and the acoustics. In fact, I wouldn't spend mega bucks on upgrades, 'til I do - there might lie the key to good sounds.
You do have quality cables right? Like Ixos.
Home > Message Board > Home Audio > Speakers > Archive through July 07, 2005 > Speakers for musical fidelity 3.2 int... [ « Previous ] [ Next » ]
