Thread: How to hook up my receiver |
New member Username: Hi4noon
Post Number: 1 Registered: Jun-05
| Posted on Monday, June 27, 2005 - 10:56 pm: |
Hi all, so yea I'm new at this and didn't expect it to be this challenging...I have a Denon avr-800 receiver and am trying to connect it to my TV...but it's being a pain. I have this red and white wire I connected to the red and white on the back of my TV but am not sure where to connect it on the receiver. on the back of the receiver there are the following options: VCR Phono CD VDP/DBS Dat/Tape for audio connections...i tried all of them with no success. and yes i did use the remote to choose the connection on the receiver. the speakers are connected correctly. I just don't know how to connect the TV to the receiver. Do I connect it to the VCR then to the receiver? not sure...I'd appreciate all help even if it comes along with insults =/ thanks |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 1023 Registered: Mar-05
| Posted on Tuesday, June 28, 2005 - 01:17 am: |
LOL, it sounds like your TV's as ancient as mine! The red and white plugs on the back of your TV are probably Audio INputs, meant for you to hook up a VCR or DVD player to play through the TV's speakers. What I do is use the tuner on my VCR to watch TV (gets better reception anyways, go figure) and hook the VCR's audio OUTputs to the receiver. |
Post Number: 2 Registered: Jun-05
| Posted on Tuesday, June 28, 2005 - 07:38 pm: |
awesome! thanks a ton for your help! I really appreciate it! ~peace |
Abubala,
Ababala
The Occupation
Post Number: 1040 Registered: Mar-05
| Posted on Wednesday, June 29, 2005 - 12:41 am: |
you're very welcome! |
Silver Member Username: Chitown
Post Number: 147 Registered: Apr-05
| Posted on Friday, July 01, 2005 - 11:38 am: |
Nathan are you sure about the model number on this? I did a quick search and I can't find a Denon avr-800. Check and repost. We can usually find the manual on-line and help you through it.
Post Number: 148 Registered: Apr-05
| Posted on Friday, July 01, 2005 - 01:15 pm: |
Does this look like the back of your receiver? http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10436919 (Look further down the page)
