Thread: Elite VSX-43TX vs. VSX-55TXi: Specific construction differences? |
AudioVideoGuy Unregistered guest |
| Posted on Monday, June 27, 2005 - 04:26 pm: |
I am curious as to what the performance differences are between the two (VSX-43TX vs. VSX-55TXi) in terms of construction etc.? The site lists some specifics, but a direct comparison, in terms of ALL the construction specifics, isn't provided. For one, it seems the 55TXi has a 'double layer' chassis, which the 43TX may not have. If anyone can provide some details of the performance and construction differences (other than functional features) between the two, I would appreciate it. Thanks!
Gold Member Username: Paul_ohstbucks
Post Number: 1401 Registered: Jan-05
| Posted on Monday, June 27, 2005 - 05:24 pm: |
The construction build quality will be the same for each model. The differences are in the features. Make your decision based on those differences. |
