Thread: Poll: used Marantz SR5000 or new Denon AVR485s |
Bronze Member Username: Duckmanx
Post Number: 30 Registered: Mar-05
| Posted on Friday, June 24, 2005 - 05:08 pm: |
used Marantz SR5000 or new Denon AVR485s Your Decision will have an effect on my choice. They are about the same price to me. I do however want Denon's 6.1 rather than the Marantz 5.1 Please post what you would choose if you had a choice between the two mentioned above. Lets say I had mid-ranged quality speakers like infinity... |
Silver Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 960 Registered: Mar-05
| Posted on Friday, June 24, 2005 - 11:07 pm: |
probably the Marantz. what price are you talking about here? There might be better options out there. |
New member Username: Rikmeister
Hometown,
Pa
Usa
Post Number: 7 Registered: Jun-05
| Posted on Saturday, June 25, 2005 - 08:00 pm: |
check out ubid for marantz and denons. and ebay for harman kardon. they give the full factory waranty are are refurbs. good deals. |
Post Number: 31 Registered: Mar-05
| Posted on Monday, June 27, 2005 - 08:35 am: |
I'll have to say denons at ecost. Marantz 5.1 over denon 6.1 why? |
Bronze Member Username: Jet2001
Post Number: 56 Registered: Mar-05
| Posted on Monday, June 27, 2005 - 09:24 am: |
check out the reviews of ecost...it was enough to scare me away. |
Hometown,
Pa
Usa
Post Number: 10 Registered: Jun-05
| Posted on Monday, June 27, 2005 - 08:35 pm: |
there are 20 denon 3805 on ubid now . |
Post Number: 32 Registered: Mar-05
| Posted on Tuesday, June 28, 2005 - 09:05 am: |
Tooo much $ for me... The marrantz is a really good deal at the same cost as a denon 485s, its that 6th channel I want... |
AudioVideoGuy Unregistered guest |
| Posted on Tuesday, June 28, 2005 - 11:06 am: |
DuckmanX, Edster asked for your budget. If you can tell us the approximate dollar amount for the two you are considering, we can see whether there are better allternatives out there for you.
Gold Member Username: Paul_ohstbucks
Post Number: 1429 Registered: Jan-05
| Posted on Tuesday, June 28, 2005 - 12:43 pm: |
If you're into movies, and have a room that will accomodate 6 or 7.1, you should go that route. It makes a difference and adds to the movie experience. |
Post Number: 33 Registered: Mar-05
| Posted on Thursday, June 30, 2005 - 10:51 am: |
My budget is sub $200 US, I am afraid I am only contemplating on those two... the Marrantz is from a guy moving and needs to shed the weight, the Denon is being shipped to me. I could always return the denon, but I am really drooling over 6.1 Thanks all. |
