Thread: Denon DCM 380 |
Bronze Member Username: Rd11
Post Number: 23 Registered: Nov-04
| Posted on Wednesday, June 22, 2005 - 11:22 am: |
Athena speakers, HK avr 635 receiver looking for a 5 disc cd changer. Looking at the Denon DCM 380. Any thoughts on this cd player? Any other choices to recommend? Thanks. |
Daniel Fell Unregistered guest |
| Posted on Thursday, June 23, 2005 - 10:53 pm: |
I've owned a DCM-370 for four years and have been generally happy with it. I believe the 380 isn't much different. Does it have to be a changer? I also own a NAD C521i (single player) which is noticeably better than the Denon for the same money ( but no HDCD decoding ). If you can go with a single player, I would recommend the NAD C521BEE..great unit for the money. Otherwise, I think the Denon is a fine choice if you absolutely need a changer or are interested in HDCD. |
Silver Member Username: Edison
Glendale,
CA
US
Post Number: 826 Registered: Dec-03
| Posted on Saturday, July 23, 2005 - 10:50 am: |
You can get the 370 on ebay often - if you are not sure that the 380 is as good (which I am not).
