Home > Message Board > Home Audio > Amps > Archive through April 21, 2004 > ADA PTM-6150 Chrome...can someone var...
Author Thread: ADA PTM-6150 Chrome...can someone varify this?
Username: Disco_stan
Minnesota
Post Number: 92
I was just browsing around and came across this amp and thought it might be worth the research. Heres the link where I came arcoss it: http://sphl.audiogon.com/cgi-bin/buy_auc.pl?ampstran&1079750329
I have no idea how it sounds or anything so I'll probably email they and get more imforation on. But if anyone doesn't mind doing outside research on this that would be great! Thanks.
and heres a pdf: http://www.ada-usa.com/Cut_Sheets/PTM-6150_Cut_Sheet.pdf
Username: Rick_b
New york
Usa
Post Number: 29
Matt,
ADA is a very good high end manufacturer. The amp in question (PTM-6150) in good condition would be a good buy at say up to $1000.00 .
Minnesota
Post Number: 93
Well thanks a lot, I'm looking to go into seperates or buying a 6 channel amp, either way I'll still be happy with what I end up with.
Home > Message Board > Home Audio > Amps > Archive through April 21, 2004 > ADA PTM-6150 Chrome...can someone var... [ « Previous ] [ Next » ]
