Home > Message Board > Home Audio > Speakers > Archive through July 07, 2005 > Outdoor speakers
Author Thread: Outdoor speakers
Any recommendations for inexpensive outdoor speakers that are decent quality? I'd like to put one speaker in the backyard and one in the sideyard.
Are the wireless outdoor speakers any good?
Username: Paul_ohstbucks
Post Number: 1323
I'd recommend a nice boombox. It's more flexible, and the controls are outside where you want them.
Username: Edison
Glendale, CA
US
Post Number: 675
I like Niles audio - sounds better than wireless speakers.
Username: Artk
Albany, Oregon
Post Number: 890
Niles or BIC.
Username: Joe_c
Oakwood, Ga
Post Number: 466
I recommend mirage oasis II whits spkrs. very good sound for 200 bucks
agm
I have a similar question with one add on...I can't put the speakers in a protected or even semi-protected area. Thoughts on a good outdoor speaker that can stand up to direct elements??
Was thinking of a simulated rock speaker -- the ones that look like rocks since they seem to be sealed pretty well.
Home > Message Board > Home Audio > Speakers > Archive through July 07, 2005 > Outdoor speakers [ « Previous ] [ Next » ]
