Home > Message Board > Home Audio > Receivers > Archive through July 12, 2005 > Which used reciever should I buy? Un...
Author Thread: Which used reciever should I buy? Under $200
Username: Sandman670
Chicago, IL
I'm looking for a used receiver (stereo, not HT).
My priorities are good sound and durability.
Any suggestions on brands? where to get one? I'd like to spend between $100-200, and I don't have great speakers at the moment but that's next on the list...
Username: Dmwiley
Post Number: 816
For 200, you could buy a new basic stereo receiver. Try Yamaha, Onkyo or Panasonic.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 906
get a refurb Harman Kardon 3480 from Harman Direct on eBay, comes with full original HK warranty. Usually goes for $160-200.
or for an extra $30 you can get the JVC RX-F10 from Amazon.com, $230 shipped. It is a 6.1 HT receiver but I've heard it in 2-channel mode and it sounds as good as receivers costing 5 times as much due to its cutting edge pure-digital technology.
Chicago, IL
one question-- is an integrated amp just a receiver without a tuner? (and therefore higher quality for the price?)
Thanks everyone for the replies and sorry for the dumb newbie questions
Username: Stu_pitt
NYC, NY
Pakistan
Post Number: 99
In a nut shell an integrated is a reciever minus the tuner. Theoretically, you should get higher quality at the same price point because you are paying the same amount of money and getting less bells and whistles. If you don't need a tuner, and intergrated amp could be a good route.
If you want to spend a couple bucks more and are going to upgrade your speakers later on, you may want to look into a vintage Marantz receiver. You can find them on e-bay. Some of the sellers restore them themselves. My father has a vintage Marantz receiver (model 2220B) and they sound great. They have low power ratings, but like most of the higher end stuff, their wattage goes a long way.
On a good day, you can find a restored Marantz for about $250. For the money, you aren't going to find anything remotely close to the sound and build quality as those. But also keep in mind that they are older and therefore require a little more pampering. If you are looking for a party system that can take a lot of abuse, this may not be the best idea.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 921
also look at the NAD integrated amps on eBay, you should be able to find something around $200.
Username: Twebbz
Ann Arbor, Michigan
Post Number: 123
You could pick up a used Yamaha "Natural Sound" Tuner Model T-15 on Ebay for dirt. They're pretty good. There are a couple available now. I have a Yamaha receiver of the same vintage and it pulls in the stations as good as any and that includes NAD and Rotel.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 943
http://www.avsforum.com/avs-vb/showthread.php?p=5763237#post5763237
After reading the above, you might want to look into the Kenwood VR7100. Anytime I hear of people preferring the sound of X over Y which costs 3-10 times as much, I tend to get very very curious...
Vanns.com has it going for $250 shipped right now. Seems to me $50 over budget is a fair price to pay in order to get something that very possibly might equal if not best, the SQ of a $3000 receiver.
Chicago, IL
I'm really not looking at getting into HT at the moment but I was wondering about the Kenwood... It's listed at 0.7% THD in stereo! I realize this is the 6 ohm rating, but there's none given for 8 ohms.
HK 3480: Continuous power (FTC): 120 Watts per channel, 20Hz – 20kHz @ <0.07% THD (and 0.2% THD @ 4 ohms).
also the kenwood looks about half as big, and with a ton more features. is there any way the sound quality is better in stereo? i find that hard to believe, but i havent heard either one.
I'm impressed by the refurbished HK's price, specs, and warranty, so I'm leaning towards that unless I can be convinced another unit has better sound for the price.
thanks
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 962
THD specs are pretty much useless, ignore them. THD doesn't even begin to be noticeable until you get to 10% and up which usually happens only in cheap ministereos.
A pure-digital receiver is almost certain to be much more detailed and crisp than analog, even to a fault according to their detractors.
And yes they are usually about 1/2 or 1/3 the size and 1/4 the weight of analog receivers.
Username: Paul_ohstbucks
Post Number: 1364
While it's true that .7% might be obvious, but it's a sign of cheapness. If they skimp on that, geez.....it makes me wonder what else they've skimped on????
.7% is not the sign of a quality built receiver. I recommend taking the hint and reading the signs, and looking elsewhere. I wouldnt consider a receiver >.1% on principle alone, because they've probably skimped throughout.
Home > Message Board > Home Audio > Receivers > Archive through July 12, 2005 > Which used reciever should I buy? Un... [ « Previous ] [ Next » ]
