Home > Message Board > Home Audio > Receivers > Archive through July 12, 2005 > Which is better quality Yamaha or the...
Author Thread: Which is better quality Yamaha or the more expensive Onkyo receivers?
wellthmaker
I am looking at the Yam HTR 5860 or 5890 and My old speakers have 19" woofers in a cabinet with high quality midrange and tweeters so I need real power.
My ear is not so sophisticated that I need NAD or HK and I like the features on the rice burners more anyway.
I was just surprised to see Yamaha price so low and wondered if they dropped their quality.
I have always been happy with Onkyo receivers you just have to over buy them, get more watts; but the surround sound just went out on mine. Only works on bypass now, So Im looking.
Username: Edison
Glendale, CA
US
Post Number: 671
You will like the onkyo TX-LR552 ... Only $200 on the web -
http://www.google.com/search?hl=en&q=onkyo+tx-lr552
Username: Artk
Albany, Oregon
Post Number: 836
Stay away from both at that price point look into Harman Kardon. You can get an HK for the same price and it will likely last longer. The HK will probably have a similar feature set.
Username: Paul_ohstbucks
Post Number: 1321
C'mon james,
based on the origional statement, do you really think he wanted a recommendation for a $200 receiver?
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 956
wellthmaker,
so what's your budget anyways?
Personally I'd look into the pure-digital receivers like the Panasonic sa-xr55, JVC 302/402, Kenwood VR-7100, HK 2005, etc. With the exception of the HK, these are all under $300 but apparently have the sound quality of receivers/amps costing several times more.
Go to avsforum.com and do a search, you'll get tons of input on them.
Anytime I read of people selling off $3000 separates in favor of a $300 receiver, I can't help getting very very curious...and I've ONLY heard of this happening with the pure-digitals.
The only one I have actually had a chance to listen to was the $230 JVC RX-F10 which was indeed extremely impressive especially considering its price.
Post Number: 1334
Hell....
Since no budget is given.....
I recommend the Yamaha RX-Z9. That will surely drive your big woofers.
Now if you're comparing the 5860 to the 5890??...well, the upper model has a superior power supply.
Username: Edison
Glendale, CA
US
Post Number: 680
The Onkyo TX-LR552 has discreet digital amp section that sounds smooth like an upscale piece - the MSRP is $400, and sounds much more expensive.
Home > Message Board > Home Audio > Receivers > Archive through July 12, 2005 > Which is better quality Yamaha or the... [ « Previous ] [ Next » ]
