Thread: Dolby Digital cuts in and out |
New member Username: Odj
Post Number: 1 Registered: Jun-05
| Posted on Sunday, June 19, 2005 - 09:24 pm: |
Can someone help me out. I have had my set up for about one year now and I have constantly had problems on regular Dolby Digital 5.1 dvds. I have a Yamaha 3650 reciever and the sound cuts out ( gets loud then soft) on those sound type movies. DTS sounds awesome but Dolby doesn't. Can someone please help me. Thanks ODJ |
Silver Member Username: Dmwiley
Post Number: 809 Registered: Feb-05
| Posted on Monday, June 20, 2005 - 08:21 am: |
Does this model automatically select Dolby or DTS or do you have to set it up for one or the other? |
Post Number: 2 Registered: Jun-05
| Posted on Monday, June 20, 2005 - 11:39 am: |
Yes it automatically sets it up on its own. My DVD player is set correctly also, I believe. I have it set on bitrate. |
Post Number: 812 Registered: Feb-05
| Posted on Monday, June 20, 2005 - 02:04 pm: |
Verify your set up on both the DVD player and receiver. Yamahas are notorius in the complexity of setup. Make certain that you don't have to manually select Dolby Digital on the receiver. Try switching DVD player to PCM. See what happens. Use a DVD that contains only a Dolby Digital soundtrack while trouble shooting. |
Post Number: 3 Registered: Jun-05
| Posted on Monday, June 20, 2005 - 02:28 pm: |
When I switch the DVD player to PCM it automatically turns the audio into ProLogic II and the sound diminishes quite a bit. |
Post Number: 4 Registered: Jun-05
| Posted on Monday, June 20, 2005 - 03:15 pm: |
Oops I mean Prologic I |
Post Number: 814 Registered: Feb-05
| Posted on Monday, June 20, 2005 - 06:21 pm: |
Sounds like a decoder problem. Is the unit still under warranty? Why did you wait a year before doing something? |
Post Number: 5 Registered: Jun-05
| Posted on Monday, June 20, 2005 - 08:28 pm: |
I have a 4 year warranty on it, so it is not a problem. It happens to my other friends with different recievers also. Could it be the DVD or does Dolby Digital have alot weaker signal than DTS? I have also noticed that it cuts in and out in the same places of the movie everytime. Somebody also told me that I need a power regulator for my whole system. Meaning that my power in my house is not clean power and the regulator cleans it for me and gives me better juice. I don't know. |
Post Number: 6 Registered: Jun-05
| Posted on Monday, June 20, 2005 - 11:28 pm: |
The cut outs do not happen on THX movies like the Star Wars saga. I just tested it. |
Post Number: 821 Registered: Feb-05
| Posted on Tuesday, June 21, 2005 - 08:44 am: |
If it "cuts in and out in the same places of the movie everytime" sounds like a defective DVD. There maybe a slight variation in volume between Dolby Digital and DTS, depending on the movie sound track mix. You should not need a power regulator under normal conditions if you live in the continental US. There may be exceptions. |
Post Number: 8 Registered: Jun-05
| Posted on Tuesday, June 21, 2005 - 10:51 am: |
Why does does it happen on non THX DVDs? Is the signal better? |
Post Number: 824 Registered: Feb-05
| Posted on Tuesday, June 21, 2005 - 03:06 pm: |
If it happens on all DVDs other than the THX ones, I suspect a decoder problem. THX discs are remastered to enhance audio and video. But you problem is a bit unusual. |
Post Number: 9 Registered: Jun-05
| Posted on Tuesday, June 21, 2005 - 08:54 pm: |
So I should check the DVD player as well as the reciever. I believe the DVD player decodes also right??
Post Number: 828 Registered: Feb-05
| Posted on Wednesday, June 22, 2005 - 09:50 am: |
Correctomundo. But if you are running digital out, DVD basically extracts and routes signal for receiver to decode. |
Bronze Member Username: Alphabet
Cape Town South Africa
Post Number: 28 Registered: Feb-05
| Posted on Thursday, June 23, 2005 - 03:09 am: |
Have you tried setting the DVD player output to "raw"? |
Post Number: 10 Registered: Jun-05
| Posted on Thursday, June 23, 2005 - 04:10 am: |
I think I only have two settings on it. PCM and bitrate. |
Bronze Member Username: Canuckinapickle
Toronto Canada
Post Number: 90 Registered: Jan-05
| Posted on Monday, June 27, 2005 - 04:23 pm: |
I had a similar problem with my system. I discovered it was a problem at the DVD player end -- for what it's worth. I upgraded my DVD player and all has been fine since. |
Bronze Member Username: Odj
Post Number: 11 Registered: Jun-05
| Posted on Friday, July 01, 2005 - 07:05 pm: |
How do I test the dvd player? How do I test the reciever?
