Thread: Paradigm Monitor V3 vs. Studio V3. |
New member Username: Nphorizon
Post Number: 1 Registered: Mar-04
| Posted on Thursday, March 11, 2004 - 12:41 am: |
Has anyone done extensive demoing and comparing of the monitor and studio V3 series speakers? Is the studio series a significant improvement and worth almost double the cost. Thanks. |
Silver Member Username: Elitefan1
Post Number: 274 Registered: Dec-03
| Posted on Thursday, March 11, 2004 - 10:36 am: |
Nick, I hope to be doing just what you ask tommorrow. I didn't think the v2 Studio 60 vs the Monitor 7 was worth double the price but I have not heard the v3 Studio's yet. Will post my response next Tuesday. |
Bronze Member Username: Bezel
Post Number: 16 Registered: Mar-04
| Posted on Thursday, March 11, 2004 - 11:42 am: |
yep. there is no double improvement but it's a tipical situation in hi-fi - you pay double and get 10-30% improvements only...
New member Username: Invierno
Post Number: 9 Registered: Feb-04
| Posted on Thursday, March 11, 2004 - 12:22 pm: |
I've compared the Monitor 5 v3 with the Studio 60 and it was no contest. The Studio 60 was much more detailed and sounded much smoother. The Monitor 5 sounded a little more rough around the edges and my ears couldn't relax as much with it -- just a little bright for me. Of course, the Monitor 5 was run off a Marantz SR7400 in one (well set up) room while the Studio 60 was run off a Rotel in a different room, so it's not truly a fair comparison. The Studio 60 was my top choice till I listened to some Dali Evidence speakers (on a NAD T763). They were also very detailed but just sounded more alive -- hard to quantify. |
Post Number: 275 Registered: Dec-03
| Posted on Thursday, March 11, 2004 - 12:43 pm: |
The Monitor 5 is not a fair comparison to make with the Studio 60 for this question. The 5 should be compared with the Studio 40 and the Studio 60 with the Monitor 7. |
New member Username: Chris
Post Number: 3 Registered: Mar-04
| Posted on Friday, March 12, 2004 - 02:20 am: |
DO you guys think that PSB image 4T sound better than Monitor 7 v3. I've compared them both and PSB sounds better to me.
New member Username: Northexposure
Post Number: 2 Registered: Feb-04
| Posted on Friday, March 12, 2004 - 04:08 pm: |
Good discussion. I'm shopping for speakers, am considering Paradigm and PSB, and appreciate learning of your experiences. I'm also consider the Axiom M60s, which at 1,080 CD are relatively inexpensive (and I may be able to get them for two-thirds that cost). Anyone listen to the Axioms? Your opinion? |
Post Number: 3 Registered: Feb-04
| Posted on Friday, March 12, 2004 - 04:10 pm: |
Chris - I hear the Image line is being replaced in a few weeks. Perhaps you can get a discount? |
Post Number: 4 Registered: Mar-04
| Posted on Saturday, March 13, 2004 - 01:03 am: |
Thanks - I'll check that out. |
Post Number: 10 Registered: Feb-04
| Posted on Saturday, March 13, 2004 - 11:07 am: |
therealelitefan and Nick: Sorry, I did actually mean Monitor 7, not Monitor 5 above. Nick and Chris: I also compared the Image 4T to the Monitor 7 and Studio 60. The 4T was a very slight improvement over the Monitor 7 for me -- it sounded a little cleaner. If the Image line is getting replaced and you like the sound of the 4T, maybe you should consider a 5T (or 6T) if they can be found discounted. |
| Posted on Monday, March 15, 2004 - 08:29 pm: |
I did extensive shopping around for speakers earlier this year and settled on the Studio 60 V.3. being run by a Yamaha 1400. The Monitor series (7's & 9's) were very good, but I found the Studio's that much better sounding that it justified the increase in price for me. Within my budget (reciever & speakers), IMO I couldn't beat the combo. When my budget allows, I will get a matching center and 20's for HT surround. |
New member Username: Robertinchico
Post Number: 1 Registered: Apr-04
| Posted on Sunday, April 11, 2004 - 02:20 pm: |
The Monitor 5v.3 is a very fine speaker for $550. I attached Straight Wire's new Symphony speaker cables during my audition and the sound had fabulous timbral accuracy. I noticed a creamy smooth and well developed midrange, with a very reasonable bass down to about 40hz. As with most Paradigm speakers, utilizing a good cable lets you hear what terrific value Paradigm's are. With the garbage cables at the dealer, the sound was smeary, lacked projection and clarity, the crossover choked and the vocals were muffled and the upper highs were badly distorted. |
