Thread: DVD / CD Player Quality with Digital Out |
New member Username: Garyo
Post Number: 10 Registered: Mar-04
| Posted on Monday, June 13, 2005 - 01:37 pm: |
If using only the digital audio output of a CD player, do I need to have a good DAC in the CD player or since the Digital to Analog conversion is in the receiver, a less expensive CD player will provide equivalent quality? |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 4045 Registered: May-04
| Posted on Monday, June 13, 2005 - 02:53 pm: |
The signal that is fed to the DAC will determine the quality of the final product. A better transport mechanism will assure the lowest error readings, aliasing distortion and jitter distortion. It's difficult to find a top notch transport in a lower priced CD player.
Silver Member Username: Edison
Glendale,
CA
US
Post Number: 666 Registered: Dec-03
| Posted on Sunday, June 19, 2005 - 09:50 am: |
Use your computer as a transport - lower jitter makes for an upscale one. There is a lot on this topic here : http://forum.audiogon.com/cgi-bin/fr.pl?icomp&1&ctg&0&50& |
