Home > Message Board > Home Audio > Amps > Archive through April 21, 2004 > Connection help!!
Author Thread: Connection help!!
Username: Nvn
My HK receiver has a pre-out section. I want to use the pre-out to connect to my Crown XLS amp input. The problem I run into is the connection on the pre-out receiver is RCA type connector and the connector on the Crown amp is a XLR type connector. Is it a good ideal that I convert the RCA to XLR with an adapter then connect to the amp? Does the source signal will be decrease?
Thanks in advance,
nvn
Home > Message Board > Home Audio > Amps > Archive through April 21, 2004 > Connection help!! [ « Previous ] [ Next » ]
