Home > Message Board > Home Audio > Integrated Amps > Archive through July 25, 2005 > DENON INTEGRATED AMPLIFIER pma2000ivr
Author Thread: DENON INTEGRATED AMPLIFIER pma2000ivr
himadri mukherjee
hows the amplifier? is it suitable for my room size 15 feet by twentyfive feet?
capww8
It's extremely well built... the sucker weighs nearly 50 lbs, and it is certainly far superior to any stereo receiver. How appropriate it is for you will be more dependent on your speakers than your room size.
thanks buddy
could u also advice whether i should go fr the denon integrated amp or rotel ra 1070c/ 1070b split pre and power combination of 130 watts per channel which almost costs the same price.
Home > Message Board > Home Audio > Integrated Amps > Archive through July 25, 2005 > DENON INTEGRATED AMPLIFIER pma2000ivr [ « Previous ] [ Next » ]
