Thread: Cambridge Audio Azur 340A + Mission M30 + iPod |
New member Username: Ewhale
Post Number: 1 Registered: May-05
| Posted on Friday, May 27, 2005 - 02:13 pm: |
I am considering getting the following set-up: Cambridge Audio Azur 340A Integrated Amp Mission M30 speakers Before I get a proper CD player I'll use my iPod's line-out as the source. I know this is really a low-budget set-up. It's only for listening to music. I listen to R&B and jazz. The system will be placed in my bedroom, which is pretty small (4 meter x 5 meter). Please comment how well this set-up will serve my purpose. Also, what are other costs I may incur? I know I'll have to spend on the cable from the amp to the speakers. I'll also need to purchase a dock for my iPod. Sorry if the question is naive. I'm only a newbie.  |
ollyb_newcastle Unregistered guest |
| Posted on Wednesday, June 08, 2005 - 04:23 pm: |
although mission do have an excellent reputation for preducing quality speakers, i do not believe they are the best option in this particular case. the speakers i would recommend to you in a budget price range are the "Eltax monitor 3" which are an amazing budget buy and definately punch well above there weight. good luck choosing olly  |
| Posted on Wednesday, June 08, 2005 - 04:25 pm: |
you dont need to purchase a dock for ur ipod, all you need is to purchase a jack to phono lead which can be very cheap depending on how good quality you want. olly |
