Home > Message Board > Home Audio > Speakers > Archive through June 05, 2005 > Having a Problem
Author Thread: Having a Problem
Username: Tspoontim
I am kind of new to this.I have a Sony surround sound system and i just checked all the connections everything is fine, but the problem my right front speaker is louder than all the the others and it gets louder as the volume decreases and also just on certain volume numbers is very loud,i switched it with another and the other speaker does the same thing, and ideas?
Username: Jan_b_vigne
Dallas, TX
Post Number: 3811
I can only assume these are Sony speakers. First thing to check would be that all the drivers in each speaker works properly. If so and this is a relatively new system, I would return to the dealer and let then investigate the situation. There are possible explanations for this behaviour, but I would want the dealer to make the determination.
Home > Message Board > Home Audio > Speakers > Archive through June 05, 2005 > Having a Problem [ « Previous ] [ Next » ]
