Home > Message Board > Home Audio > Phono > Archive through June 06, 2005 > Help with a technics sl-n5
Author Thread: Help with a technics sl-n5
amonar19
Hi
I have just recieved an old technics sl-n5- my first tt in more then 20 years. There is a definite hum every time the TT is connected to the mm input on my preamp. However I couldn't find any slot to place a grounding wire on the Technics. Where should it be connected?
Username: Jan_b_vigne
Dallas, TX
Post Number: 3779
Normally it is next to the lead outs of the table. There should be a lug to attach a wire if the ground cable is not already attached.
amonar19
Dear Jan
Thanks! However that's what I also assumed, but there is no lug there. Any other advide as to where I can attach it to?
Home > Message Board > Home Audio > Phono > Archive through June 06, 2005 > Help with a technics sl-n5 [ « Previous ] [ Next » ]
