Home > Message Board > Home Audio > Speakers > Archive through June 05, 2005 > Soundstage???
Author Thread: Soundstage???
Username: Kinggimp82
hey im a newbie. what exactly is soundstage? ive heard the term but dont really know what it means.
Username: Paul_ohstbucks
Post Number: 954
Put simply, the term refers to how well the sound fills your room. When it comes to creating a soundstage and filling your room with sound, speakers are not created as equals and can be 'night/day' different from one another.
Also, a speaker thats well matched for one room, might be terrible for another. Small speakers and large listening areas usually make for a poor combo.
Username: Petergalbraith
Rimouski, Quebec
Post Number: 567
Maybe Paul was imprecise or maybe I disagree.
Soundstage, for me, isn't how sound fills the whole, but how well the speakers' sound images into a "stage" with different instruments that are localized in certain areas in front of you.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 553
I usually see the word "soundstage" used according to Peter's definition.
http://www.audiovideo101.com/dictionary/dictionary_cat.asp?catid=16
Soundstage: The perceived width, depth and height of recorded sound played back over an audio system; the setting similar to a theater stage from which sounds seem to emanate when reproduced through an audio system (see Imaging).
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 554
The below is from Stereophile's Audio Glossary
http://www.integracoustics.com/MUG/MUG/bbs/stereophile_audio-glossary.html
soundstaging, soundstage presentation: The accuracy with which a reproducing system conveys audible information about the size, shape, and acoustical characteristics of the original recording space and the placement of the performers within it.
soundstage shift: Apparent lateral movement of the soundstage when listening from either side of the sweet spot.
Username: Jan_b_vigne
Dallas, TX
Post Number: 3782
http://forum.ecoustics.com/bbs/messages/1/56618.html
Dallas, TX
Post Number: 3783
http://lp2cd.com/audio_terms/a/index.html
http://harada-sound.com/sound/handbook/defa-d.html
Username: Dmwiley
Post Number: 680
Peter has it right. Imagine sitting in front of a stage where a live performance is taking place. You can see and hear where the various instruments are located, especially in an orchestra or accoustic performance. Good speakers reproduce this experience (at least in the audio context).
Home > Message Board > Home Audio > Speakers > Archive through June 05, 2005 > Soundstage??? [ « Previous ] [ Next » ]
