Thread: Interference/crackle only during dvd video play back |
New member Username: Trdjohn
Suburban Chicago
Post Number: 1 Registered: May-05
| Posted on Tuesday, May 24, 2005 - 12:31 am: |
Ok this is my set up. I have a Yamaha V620 a/v receiver, Sony DVD/SACD 875 player & Panasonic DVD player with Paradigm 90 Cinema series left, right & CC. Both DVD players have been set up with optical out to optical in on A/V receiver. (dvd players are NOT hooked up at same time) The problem: during playback of DVDs (doesn't matter if dolby or dts) in 5.1 and only during 5.1 playback am I getting a crackle in only the left & right speakers, the center channel is crystal clear. This happens with either DVD player. If I play back DVDs thru the analog left & right speakers hookup they sound fine. Regular CDs and SACDs play back fine thru the same left & right speakers. I've got both the receiver and dvd players players hooked up correctly and have their software settings correct. So I am ruling out the speakers having problems. I am ruling out a bad optical cable, cause the center channel is fine and all three would be affected, right? Using similar reasoning (& I've tried using different optical inputs on the receiver) that the inputs are not bad. Now I have NOT tried sending it out a digital coax to receiver digital coax input. Nor have I tried sending it via 6 channel analog output. But have a funny feeling that won't matter (maybe I am wrong) Something in my gut says the A/V receiver isn't handling/decoding the left & right channels correctly. Anyone ever run into this? Any other ideas? Thanks in advance for the collective wisdom of the group. If I posted this in the wrong sub-forum, the moderator should feel free to move to the correct folder. |
Silver Member Username: Paul_ohstbucks
Post Number: 935 Registered: Jan-05
| Posted on Tuesday, May 24, 2005 - 12:55 am: |
One thing to check..... Go into your DVD player setup options and make sure your are properly formatted for a DD optical connection. |
Silver Member Username: Kano
Post Number: 497 Registered: Oct-04
| Posted on Tuesday, May 24, 2005 - 03:58 am: |
I'd try a new cable. |
