Home > Message Board > Home Audio > MP3 and Digital Audio Players > Archive through June 29, 2005 > Wav To Mp3,Mp3 To Wav,Mp3 Wav Convert...
Author Thread: Wav To Mp3,Mp3 To Wav,Mp3 Wav Converter,Mp3 To Wav Converter,Convert Mp3 To Wav,Convert Wav To Mp3
Username: Rebecca
Cool Mp3 Converter is a tool that lets you convert files in batches from MP3 to WAV and back. It converts MP3 files to WAV format for burning onto CD and converts WAV files to MP3 format for listening to your favorite music in smaller size and compatible with most MP3 player.
The tool also has a built-in player that can playback either single file or all the files in a list in batches. It also makes a distinction between playing the source file and the converted version so that you could appreciate the difference in quality before you convert the whole collection. There's also an ID3 tag editor and some more minor but useful features.
Software Features:
1.Fast encode and decode MP3 files with high quality
2.Converts .MP3,.MP2,.MP1 into CD quality format WAV files ready to burn.
3.Converts .WAV into .MP3
4.Converts music play lists (.M3U, .PLS) to WAV
5.Convert audio files in batches
6.Easy to add audio files to convert - Just one right click of mouse!!
7.Play audio files in batches
8.Display & Edit MPEG file ID3 tags
9.Well-designed, easy-to-use interface
http://www.mp3towav.org/Cool-MP3-Converter/
Username: Chenliang
Easy CD Ripper v2.27 Support:
Extract audio CD tracks to audio formats MP3, APE, WAV, WMA, VQF, OGG Vorbis with excellent output quality and high ripping speed.
Convert audio formats MP3, WAV, WMA, APE, VQF, OGG from one format to another--this is what the new feature File Converter does.
Clone CD into image file bit by bit perfectly, HDCD and DTSCD etc..are supported now.
Unlimited sample rates converter support from 9600 to 192000 sample rate.
Full support FreeCDDB and ID3, you can get the music info from internet easily and edit the music info yourself professionally.
In the support of Sync Play, you can compress and listen to the music at the same time.
Convert CD digitally and directly into music files , no temporary wav file used, saving your hard disk and make it faster!
Use The latest Lame encoder and options dialog for professional Mp3 encoding.
Just one click to finish converting, everyone can use it even a child.
Home > Message Board > Home Audio > MP3 and Digital Audio Players > Archive through June 29, 2005 > Wav To Mp3,Mp3 To Wav,Mp3 Wav Convert... [ « Previous ] [ Next » ]
